Bodet BT659 slave
  • Bodet BT659
    • Jun 2021
    Bodet BT659 slave
    Hi,
    I am a clock collector who recently expanded the collection with a Bodet BT 659 serie 5 slave clock. I would like to connect this slave to my TN master clock. For this I am looking for the user manual and the plexiglass window has a crack.
    - Does anyone have a user manual that would share this with me?
    - And does anyone have a whole plexiglass window that will sell this to me?
    Thanks, Coen
    That's a beauty! What sort of plug does it have to connect it to a master? That alone might help steer you to an answer.
    Welcome aboard!
      • 2247
      I forgot about this thread, apologies!
      I think you might be looking for a very specific manual for the 'regular' manual will only tell you how to connect this clock to 220v or insert batteries into it and set the time.
      With regard to a plexi glass, I only have one for the older model, it is more rounded and not so much 90 degrees angled on the sides as yours, so cannot be of much help there.
      • Bodet BT659
        • Jun 2021
        It is a very nice piece which I am very happy with. Regarding to the plug: it has a wallmounting bracked which comes with two wires to connect to the master and it should be possible to set the voltage according to the master clock. I didn't have the time jet to open it but i guess it will be self explanatory.
        It's not rocket science but I would like to have the manual. I like the story behind the clocks. Sorry but that's a tick i have that comes with collecting clocks .
        • eathan21th
          • Jan 2016
          • 116
          Maybe these threads may help.
          Hallo Flip clock fans, is it anybody over there who can help me with following issue, please? I bought Bodet clock BT 659 some time ago and I would like to use it as a slave clock for my Brillie mother clock. Brillie mother clock distributes 30 seconds impulses with aternated polarity of voltage. I can use voltage from 1,5 V to
          Hello all, This is my first post but I would like to share my little project with you. I bought my Bodet BT659 on an auction site a while ago and decided to
          • flippin' 'eck
            • 6
            Have you opened it up? I've had 14 of these slave clocks and self powered versions and every single one has had the instructionleaflet (with wiring pin guide) folded up tightly under a little plastic clip inside the clock!
